It is currently Sun Sep 14, 2025 7:11 am
PostPosted: Fri Dec 02, 2016 9:27 am
First name: Rahoul
Last Name: waghmare
City: pune
State: maharashtra
Zip/Postal Code: 411044
Country: india
Hello friends.
i got one cnc router in my vicinity who can cut fret slots.
my fretwire is 0.45 mm tang.
so i should go for 0.4 mm endmill or 0.5 mm as 0.45 mm is not available.
and also which endmill should i use HSS or carbide?
and most imp. what should be spindle speed and feed speed.
waiting for ur advices.
thanks in advance
PostPosted: Sat Dec 03, 2016 4:36 pm
Last Name: Fifield
City: San Jose
Zip/Postal Code: 95124
www.precisebits.com
Everything you need to buy/know is there.
Cheers,
Cambrian Guitars
PostPosted: Sun Dec 04, 2016 1:18 am
First name: Rahoul
Last Name: waghmare
City: pune
State: maharashtra
Country: india
Thanks sir for the link
but wat should be the spindle speed and feed speed for slots?
PostPosted: Sun Dec 04, 2016 10:46 am
City: Escondido
Zip/Postal Code: 92029
If you search this forum you will find where this has been discussed before. As with everything having to do with this craft, there is no one right answer. However, there have been lengthy and informative discussions where you can get the info you need. Good luck!
PostPosted: Fri Dec 09, 2016 8:54 am
I usually shoot for about .0005"/tooth but I also cut full depth in one pass. You might be able to get away with a bit more if you're not going full depth I would think.
